Mil24cb
May 31, 2022Aspirant
RND 2110 V1
Hi folks, just purchased a s/h NAT as in the title. I have the thing working, but when I click admin on the RAIDar, I get the following error in my browser: This site can’t provide a secure conn...
Jun 01, 2022Guru - Experienced User
This site can’t provide a secure connection
192.168.1.244 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
You'll need to use an old browser - FireFox 94.0.2 will connect, as will the current version of internet explorer. If you go with FireFox, make sure you immediately reconfigure it to turn off autoupdate. Note you will get a certificate error (not the same as the SSL version mismatch), that you will need to click through.
You can either stick with that solution, or you can edit virtual.conf as described here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
Mil24cb
Jun 01, 2022Aspirant
Brilliant thank you!
