hamslice's avatar
hamslice
RND2110 V1 - can be seen and logged into, no shares seen
Hello, I had this as a previous topic, but lost the link for a few days, and when I found it again, it was locked. Below is the original post and response. Since then I have found the Nas is an RND2...
  • StephenB's avatar
    Jul 02, 2020
    If you want to access the web admin ui, you need to browse to http://nas-ip-address/admin
    If you leave the admin bit off, you end up looking at a share list.  This will only show shares that have http enabled as a sharing protocol, so after a factory reset it will be empty.
    Have you tried using \\nas-ip-address in file explorer (not clicking on the NAS in the network list)?  Be careful to use the backslash, as the forward slash will open your browser.
ProSupport for Business
