exibar's avatar
exibar
rndp6000-200 saga continues :-(
so my saga continues.  I ahve all good drives now, with zero unrecoverable sectors.  I was able to make a raid1 array no problems with it.  XRAID.    I got in another pair of identical drives, verif...
  • exibar's avatar
    exibar
    Jun 03, 2022
    so I think I found the root cause of my issue 🙂
    I verified everything was good, from PSU, to the drives, the CPU, to the connections... everything...  except for one item, the memory.
    I ran a memory test and the error count kept rising and rising took like 15 mins to get to 747 errors...
    I pulled one module out and the errors went away.
    I replaced them both with one of mine from the shelf and it verified perfection, 0 errors.
    so I threw 6 256G drives in, started a factory reset (which never really completed before), and it went through first pass, no issues and really quickly.
       I'm initializing the array right now 6x265G drives and it says it should only take an hour and a half... so far things are fully usable and operational even during the array initialization (resynch).
    So it's looking good right now but I don't wanna jinx anything 🙂  I'll ahve to dig out 2x4Gig DDR2 ram sticks...  I have a full tray of 4G ram, wish I could use those, there are maybe 36 sticks sitting there in the tray gathering dust on the cover ;-(
ProSupport for Business
