Archdivan
Jan 11, 2019Aspirant
RNDP6000 vith OS6 and readycloud
HI! There is known issue: RNDP6000 with OS 6 has no s/n and numbers are the same with MAC adress of device. that way i can't access to readycloud. also i know that legacy has no support but it seems to easy-solved, so i ask for some help. sorry for my poor english.:catembarrassed:
Hi Archdivan,
The fix has been applied already and the NAS was rebooted afterwards. The unit should have the actual serial number now.
- JohnCM_SNETGEAR Employee Retired
Hi Archdivan,
Welcome to the Community!
Can you take a picture of the serial number and the MAC address of the NAS? That is usually located at the back or underneath of the chassis. Please PM it to me afterwards.
Hi Archdivan,
