Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
Etz
Mar 24, 2012Aspirant
Yes I want to make some of the settings permanent...
Unfortunately I cannot find any trace of rtorrent config file... :?
RuTorrent is only WebGUI frontend, my question is about rtorrent config...
EDIT: OK, it wasnt the addon issue at all.
Basically I had a strange problem, where Downloads share wasnt writable to that addon.
Changed share owner to nobody, and all began to work as expected.
Still would like to know where are rtorrent default settings are kept... :P
