Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
invader980
Mar 25, 2012Aspirant
Etz wrote: Yes I want to make some of the settings permanent...
Unfortunately I cannot find any trace of rtorrent config file... :?
RuTorrent is only WebGUI frontend, my question is about rtorrent config...
EDIT: OK, it wasnt the addon issue at all.
Basically I had a strange problem, where Downloads share wasnt writable to that addon.
Changed share owner to nobody, and all began to work as expected.
Still would like to know where are rtorrent default settings are kept... :P
i miss understood .. i get u now ,Ran into a similar issue my self and same solution lol .
as far as the rtorrent config ... im not exactly sure were it is either, did some searching my self with no luck . i assume if u really wanted to find it u could ssh into ur box and find the dir.... but u really dont interface with rtorrent at all with rutorrent running ... i assume anything ur trying to set in the rotrrent.rc u could have set by rutorrent (editing php files) for u as the webgui will load up with it anyway ... only limitation would be that rutorrent would have to be up and going .
then again it would be alot easier to just edit the file to ur liking .... gives u the ability to cause more harm then good im guessing tho lol
this app kicks arse ... cant live with out it
