Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
Dewdman42
Jun 21, 2012Virtuoso
i did not try to use the autotools feature because so far it looked to have less control then what I can do directly with rtorrent. Maybe later I will come back to that.
bit torrent can allow or force encryption of the data stream so that your ISP can't detect you're doing torrents more or less. Some ISP's will throttle your bandwidth if they figure out you're torrenting. Utorrent and most torrent clients provide this. Google around.
