Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
Dewdman42
Jun 24, 2012Virtuoso
in answer to your question about ~admin/.rtorrent.rc.
In unix you can refer to your own home dir with the '~'. So if you were going to save the file to the home dir of the current user, you'd say ~/.rtorrent.rc.
However in unix if you put a username after the tilde, then its referring to the home dir of that user.
Check /etc/passwd to see what the home dir is for your admin user. On my system it was /home/admin
