Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
Dewdman42
Jun 24, 2012Virtuoso
like I said, you have to edit the rtorrent.rc file and change some of the paths, you can't just use exactly what I used. Fix that. Check all the permissions
