Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
invader980
Jun 24, 2012Aspirant
Figured out the problem with the rc file .... Simply editing it in windows ruined the line returns and such i had to download an editer to edit the file correctly ...
.. i am usding front view to start and stop rtorrent ...
assumming the same thing happend with start up i also re-made RUTORRENT_service .. im up and running ( i think will have to test the session part is working)
WOOT WOOT --- told u i was a linux noob lol learned alot tho :
for other noobs out there = i used Komodo Edit 7.0 to edit the files and u have to change the file prefrences /line ending to UNIX (\n) to prevent issues if u edited the files in windows
thanks for trying to help me Dewdman i know its frustration when the user should know better :) lol
