Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
wizzard
Jul 05, 2012Aspirant
I need a second pair of eyes to se what I have done wrong. I have earlier had rtorrent running on ubuntu
Symtoms:
- Torrents will not autoload from watched catalogs
- Torrents can not be started, they are stuck in PAUSED (Save as catalog is "./" acording to rutorrent)
- If I restart torrents are gone from rtorrent.
My .rtorrent.rc
Symtoms:
My .rtorrent.rc
s is an example resource file for rTorrent. Copy to
# ~/.rtorrent.rc and enable/modify the options as needed. Remember to
# uncomment the options you wish to enable.
# Maximum and minimum number of peers to connect to per torrent.
#min_peers = 40
#max_peers = 100
# Same as above but for seeding completed torrents (-1 = same as downloading)
#min_peers_seed = 10
#max_peers_seed = 50
# Maximum number of simultanious uploads per torrent.
#max_uploads = 15
# Global upload and download rate in KiB. "0" for unlimited.
#download_rate = 0
#upload_rate = 0
# Default directory to save the downloaded torrents.
directory = /c/media/temp/download/
# Default session directory. Make sure you don't run multiple instance
# of rtorrent using the same session directory. Perhaps using a
# relative path?
session = /c/.rtorrent/session
# Watch a directory for new torrents, and stop those that have been
# deleted.
#schedule = watch_directory,5,5,load_start=./watch/*.torrent
#schedule = untied_directory,5,5,stop_untied=
# Close torrents when diskspace is low.
#schedule = low_diskspace,5,60,close_low_diskspace=100M
# The ip address reported to the tracker.
#ip = 127.0.0.1
# The ip address the listening socket and outgoing connections is
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
# Port range to use for listening.
port_range = 6890-6990
# Start opening ports at a random position within the port range.
port_random = yes
# Check hash for finished torrents. Might be usefull until the bug is
# fixed that causes lack of diskspace not to be properly reported.
check_hash = yes
# Set whetever the client should try to connect to UDP trackers.
#use_udp_trackers = yes
# Alternative calls to bind and ip that should handle dynamic ip's.#schedule = ip_tick,0,1800,ip=rakshasa
#schedule = bind_tick,0,1800,bind=rakshasa
# Encryption options, set to none (default) or any combination of the following:
# allow_incoming, try_outgoing, require, require_RC4, enable_retry, prefer_plaintext
# The example value allows incoming encrypted connections, starts unencrypted
# outgoing connections but retries with encryption if they fail, preferring
# plaintext to RC4 encryption after the encrypted handshake
#encryption = require,enable_retry,prefer_plaintext
# Enable DHT support for trackerless torrents or when all trackers are down.
# May be set to "disable" (completely disable DHT), "off" (do not start DHT),
# "auto" (start and stop DHT as needed), or "on" (start DHT immediately).
# The default is "off". For DHT to work, a session directory must be defined.
dht = disable
# UDP port to use for DHT.
# dht_port = 6881
# Enable peer exchange (for torrents not marked private)
# peer_exchange = yes
# chmod rwx for everybody
system.umask.set = 0000
# Schedules to watch folders
schedule = watch_directory_1,11,20,"load_start=/c/media/temp/default/*.torrent,d.set_custom1=/c/media/default/"
schedule = watch_directory_2,12,20,"load_start=/c/media/temp/music/*.torrent,d.set_custom1=/c/media/Music/"
schedule = watch_directory_3,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_4,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_5,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_6,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_7,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_8,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_9,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_10,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_11,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_12,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
# Move completed downloads to preset target
system.method.set_key = event.download.finished,move_complete,"d.set_directory=$d.get_custom1=;execute=mv,-u,$d.get_base_path=,$d.get_custom1="
# Do not modify the following parameters unless you know what you're doing.
# Hash read-ahead controls how many MB to request the kernel to read
# ahead. If the value is too low the disk may not be fully utilized,
# while if too high the kernel might not be able to keep the read
# pages in memory thus end up trashing.
#hash_read_ahead = 10
# Interval between attempts to check the hash, in milliseconds.
#hash_interval = 100
# Number of attempts to check the hash while using the mincore status,
# before forcing. Overworked systems might need lower values to get a
# decent hash checking rate.
#hash_max_tries = 10
