Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
Dewdman42
Jul 05, 2012Virtuoso
There are a few little quirks. For example I have found with the watch feature that if you remove the .torrent files after they've been collected that when it finishes it will get into some kind of stuck state for that torrent and won't start seeding it right. So I plop them in the watch dir, I wait until they have been swept up, then I remove them. There is supposedly a .rctorrent.rc script floating around that will move the torrent files after they are swept up, automatically, but I haven't had time to pursue it.
