Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings? It always defaults back to factory settings if you reboot ReadyNAS or restart addon. It`s a known behaviour of ruTorr...
Vatoe
Jul 08, 2012Aspirant
I have a problem. When I try to download a torrent (from torrent file) I get "Bad response from server: (500 [error,list]) Link to XMLRPC failed. May be, rTorrent is down?". Does anyone know what this means and how I can fix the problem?? After this error message, nothing works, I get thios message: "09.07.2012 15:42:24] Bad link to rTorrent. Check if it is really running. Check $scgi_port and $scgi_host settings in config.php and scgi_port in rTorrent configuration file." Restarting the service on the NVX just reproduces all the same problems..and as I have indicated elsewhere, I cant seem any torrent client to run, including Transmission (which used to work) and I even tried the uTorrent which doesnt work.
edit: fixed by reinstalling the ReadyNAs firmware.
