Etz
Mar 21, 2012Aspirant
ruTorrent 3.3 + rTorrent by WhoCares
Can someone explain, how to configure download directories and other settings?
It always defaults back to factory settings if you reboot ReadyNAS or restart addon.
It`s a known behaviour of ruTorrent GUI: http://forums.rutorrent.org/index.php?topic=570.0
Also I couldnt find corresponding rtorrent.rc file anywhere in my unit, so where are the default settings actually kept? :roll:
Basically my problem is, that it always defaults download directory to /c/media , which I have deleted because I use different share names... (Downloads for example) :?
- NetWhizGuideThank you for this excellent post. I hope you continue with your experiments and post your results as you find new settings/scripts/apps that work.
- sendjesAspirantNew guy here, just about to install this addon, hopefully i'll get it to work, if not, i'll either edit this post, or reply if any new replies are in, thanks again.
*EDIT* My first addon ever installed, well after the PHP addon ofcourse, and it seems to be working flawlessly. - humbleusAspirantReadyNAS:/etc/frontview/addons/bin/RUTORRENT# /usr/bin/rtorrent -o scgi_local=/tmp/rutorrent.sock
/usr/bin/rtorrent: /usr/local/lib/libcurl.so.4: no version information available (required by /usr/bin/rtorrent)
rtorrent: Error in option file: ~/.rtorrent.rc:85: Command "system.umask.set" does not exist.
I'm guessing system.umask.set has been deprecated..
Any way around this? - dp106AspirantNot sure if anyone still looks at this thread as its very old... :)
I've just installed this addon and tried to follow all the steps here. Had loads of issues so in the end decided to start again with a fresh version of .rtorrent.rc to see if I could at least get it to start rtorrent.
This worked so I gradually added the customisations back. Everything worked until I added this one to modify the file permissions:# chmod rwx for everybody
system.umask.set = 0000
Taking this back off and it works again but leaves admin as the owner. Any idea how I can fix this?
