Cledus's avatar
Cledus
rutorrent and security
Hi!
I have installed rutorrent and PHP5 5.3.8. Everything works fine but I'm a little concerned about security. There is no login in to the rutorrent interface and there is allot of php stuff installed that I don't know if it's secure. Do I have to do anything else to get good security?
Thanks!
  • Thanks for the reply bbaraniec!
    Adding htaccess only secures the webinterface dosn't it?
    I'm more concerned about hacking of my nas due to security holes in having a lot of phpservices that I don't have any knowledge about. Is there any security risks other than the webingerface beeing accesseble without password?
    Otherwise I don't understand why people struggle with other bittorrent client. Rutorrent has everyting
    Thanks again for the reply!
  • Yes, it's gonna secure web interface only. I'm not using php on Nas myself nor using Torrents.
    Security holes are being found on daily basis in more sophisticated software then php bittorrent client. Use strong password, forward only services that you need, use SSL and you should be fine.
  • Thanks to great community ReadyNas addons are updated pretty fast but still you can't be 100% sure that you are safe.
    Like I said, use different usernames and strong passwords, use SSL, limit ip ranges allowed to access your services, etc.
ProSupport for Business
