wallynas
Sep 30, 2012Aspirant
SABnzbd 0.7.3 "No UNRAR program found"
I just bought, downloaded and installed Python 2.7 and SABnzbd 0.7.3 for my NV+. Went through the installation steps, it can connect to my usenet provider (using SSL if that matters). However I ge...
wallynas
Received this email:
Dear ReadyNAS User,
After the release of the SABnzbd (Sparc) add-on a fellow user found that in some cases the UNRAR utility won't get installed on fresh installs of the add-on. To fix this issue, the attached updated add-on was released and is sent out to you for updating.
To update you current install of the SABnzbd add-on, please install the attached version over the existing version on your ReadyNAS. Do NOT uninstall the currently installed version.
Sincere apologies for this inconvenience.
Best regards,
ReadyNAS Xtras
I downloaded and installed the update, but now I get a warning saying "Your UNRAR version is not recommended, get it from http://www.rarlab.com/rar_add.htm"
Dear ReadyNAS User,
Best regards,
ReadyNAS Xtras
