wallynas
Sep 30, 2012Aspirant
SABnzbd 0.7.3 "No UNRAR program found"
I just bought, downloaded and installed Python 2.7 and SABnzbd 0.7.3 for my NV+. Went through the installation steps, it can connect to my usenet provider (using SSL if that matters). However I ge...
gibxxi
Aug 21, 2013Guide
You don't. Either use the one installed by default, or the one bundled with the version of Sabnzbd you purchase from WhoCares.
