wallynas
Sep 30, 2012Aspirant
SABnzbd 0.7.3 "No UNRAR program found"
I just bought, downloaded and installed Python 2.7 and SABnzbd 0.7.3 for my NV+. Went through the installation steps, it can connect to my usenet provider (using SSL if that matters). However I ge...
gibxxi
Aug 24, 2013Guide
Reinstall whichever version of SABnzbd you have over the top of itself. If you've installed Transmission (or an update to it) by Super-Poussin, it will replace the UNRAR version installed by SABnzbd with an older (not recommend) version. Re-installing SABnzbd over the top of itself will solve this problem.
