zom414
Nov 16, 2010Aspirant
SABnzbd Folder Help Required
I have installed both Python and SABnzbd (latest versions) on my NV+ and set it up. However, I'm having trouble with my folders. I have created the following folders: /c/media/sabnzb/complete /c...
zom414
Nov 19, 2010Aspirant
Sorted out this problem and the folders are now showing (not sure what I did to fix it though!).
Got another problem now though. When the file is loaded I then get an error message stating that the nzb file could not be cleared from the folder. This option has worked on other versions of nzb that I have used. Can anyone help?
