Carnaged
Dec 14, 2012Tutor
Sabnzbd no install directory on Nas
I have installed Sabnzbd and changed the download folder to the following; /d/Downloads/complete I have set permissions to 777, my D partition is my media drive as C is used for work backup. I d...
gibxxi
Dec 14, 2012Guide
Your going to want to set your Temporary Download Folder in Sabnzbd+ to somewhere accessable to normal users. I set mine to:
As for failed jobs which haven't been deleted, go to Sabnzbd's Status -> Queue Repair menu, and you can delete any jobs which failed, and the NZB was deleted from the queue, but the files were not removed.
/Downloads/Usenet Downloads/Files (Incomplete)and the completed downloads folder to:
/Downloads/Usenet Downloads/Files (Complete)Your going to want to set the owner/group for your "Downloads" share to admin/nobody. Otherwise Sabnzbd+ will keep bugging you that it's unable to change the permissions on your incomplete folder. It does this when downloading to stop access by other users and hence corruption of the downloaded data. Once the queue is clear, Sabnzbd+ seems to open up the folder for general access again, so that residual cleanup can be resumed.
