sshambar2
Sep 16, 2020Star
Samba 3.6.25 build for ReadyNAS NV+ v2
My brother was having difficulties connecting to his ReadyNAS from his work laptop running Win10, and asked if I could enable SMB2 on his NAS (he couldn't install SMB1 compatibility as the laptop is ...
Sandshark
Sep 16, 2020Sensei
That's great! Since many users are unfamiliar and/or uncomfortable with SSH access and the Linux command prompt, it would be even better if it could be offered as an add-on. Any chance you or somebody else interested could build one?
I'd volunteer, but I'm not a Linux programmer and have found no "ReadyNAS package building for dummies" guide. The available instructions clearly assume you are a programming guru.
sshambar2
Sep 23, 2020Star
I've created a Samba 3.6 add-on using the old ReadyNAS Add-On SDK (thanks mdgm for the pointer). The initial release can be found at:
https://github.com/sshambar/readynas-arm/releases/download/Samba36-3.6.25-1/Samba36_3.6.25-1.bin
Once installed, the add-on will run the new Samba 3.6 version. There's an option to disable SMB2 support if you want, but it's probably best to leave it enabled. If the add-on is disabled (or removed), the original 3.5 Samba server is restored and started. Re-enabling the add-on will again start the new 3.6 version.
I also created scripts and Makefiles so if anyone wants to rebuild (or fix) the add-on, it's pretty easy. Basically the add-on is a wrapper around a debian package (to allow removal), which is built from the binary tarfile.
The READMEs describe how it all works, but if you have the various SDKs installed, you should be able to build everything without difficulty.
Let me know if you have any problems.
- StephenBSep 23, 2020Guru - Experienced User
Thanks for posting this!
I don't have own the NV+ v2, but I suspect many folks will find this useful.
