sshambar2
Sep 16, 2020Star
Samba 3.6.25 build for ReadyNAS NV+ v2
My brother was having difficulties connecting to his ReadyNAS from his work laptop running Win10, and asked if I could enable SMB2 on his NAS (he couldn't install SMB1 compatibility as the laptop is ...
Sandshark
Sep 24, 2020Sensei
I get the dreaded "Unknown server error" when I try to upload this to my Duo V2. But that may not be a fault with the package itself.
p-tr
Oct 14, 2020Initiate
The message "Unknown server error" is because You use Chrome or newer browser.
Try using older Internet Explorer and it works.
- SandsharkOct 16, 2020Sensei
p-tr wrote:The message "Unknown server error" is because You use Chrome or newer browser.
Not in this case.
- treboR2RobertNov 29, 2020Aspirant
I tried installing using edge and got the server error.
I then tried using internet explorer as directed and it installed fine.
HOWEVER
I cannot access the shares from my windows 10 laptop.
I tried all sorts of things to fix it but the only way I can access the shares is to enable smb1 in windows.
The addon tells me it installed correctly and when i click on it everything seems ok but i have no access to the shares.
I installed ssh and dug around inside the usr/sbin folder and found that the addon seemed to have changed smbd and nmbd to .orig files and the new ones are linked to usr/local/sbin
And the files smbd and nmbd seem to both be in usr/local/sbinso it seems the addon done its job but something is wrong ???
If i disable the addon and turn smb off and back on again from the web interface and try to connect to the share using windows then windows pops up and says i cant connect because its smb1.
I then re-enable the addon and windows just says
attempting to connect for ages then says it cant access the share try checking the name or there might be a problem with your network.
(the same happens if i turn smb off and back on from the web interface after enabling the addon) (and the same happens if i restart the whole unit)
If I disable the addon but DO NOT turn smb off and on from the web interface i get the same message saying attempting to connect for ages and then windows can't access the share, check the spelling etc..
And as i said above if i turn smb off and back on after disabling the addon from the web interface and try connecting again it now says it can't connect because it smb1.
- sshambar2Nov 30, 2020Star
If you have ssh access, it might be easiest to check the following with the plugin installed and SMB2 enabled:
1) if the smbd daemon is running: "ps -ef | grep smbd", should show one or more:
root 1955 1 0 Nov15 ? 00:00:00 /usr/sbin/smbd -D
root 1981 1955 0 Nov15 ? 00:00:00 /usr/sbin/smbd -D
root 7264 1955 0 08:47 ? 00:00:00 /usr/sbin/smbd -D2) the Samba logs: "more /var/log/samba/log.smbd", should include something like:
[2020/11/15 17:28:16, 0] smbd/server.c:1072(main)
smbd version 3.6.25 started.
Copyright Andrew Tridgell and the Samba Team 1992-20113) try local client to confirm daemon is working: "smbclient -N -L //readynas" (replace readynas with your server name), should display a list of your shares.
4) make sure SMB2 include files are being loaded:
"grep include /etc/samba/smb.conf" should have "include = /etc/frontview/samba/addons/addons.conf" on the list
"grep include /etc/frontview/samba/addons/addons.conf" should have "include = /etc/frontview/samba/addons/SAMBA36.conf" as output
"cat /etc/frontview/samba/addons/SAMBA36.conf" should contain:
[global]
# enable SMB2 support
max protocol = SMB25) If all that looks ok, then you can also try running smbd directly with debug output.
stop current daemon: "/etc/init.d/samba stop"
start samba directly: "/usr/bin/smbd -i -d 1"
... then try to connect from Win10 (-i makes it quit after 1 connection though!)
Something on that list should give you a good idea of what's not working :)
Good luck,
Scott
