rajivvishwa
Feb 07, 2014Aspirant
Setup Softether VPN
I'm trying to understand how to setup VPN server on my readyNAS device. My objective is to access internet securely while I'm connected to public wifi networks from outside. So I'm assuming that a...
sergiomarina
Jan 23, 2015Aspirant
Hi Rajivvishwa, I suggest you to download a launch the VPN server manager. Using it you will be able to create a user so that the client can connect.
According to my reading/underestanding of your post, I had the same issue and I solved as I wrote here above. Two weeks ago I bought a RN102 (I have also seen this coding RN10200).
In summary there are two distinct download you need to carry out: VPN Client manager and VPN Server manager (both are from SoftEther website). In my case, both executable were for Windows but you choose according the operating system you are using.
Stay in touch. We are working on the same tasks :)
- Nov 05, 2017Retired_Member
