jonbloke3276
Jan 28, 2024Aspirant
Shared folders disappeared RN3138
Hi, Hoping someone can point me in the right direction here. I'm currently using a ReadyNas 3138 as a Plex media server and general all round file server. Had it a couple of years and until r...
Jan 28, 2024Guru - Experienced User
Are you seeing any warnings that the root is full?
Do you have a backup of the files?
jonbloke3276
Jan 29, 2024Aspirant
loads of free space available - 6.6TB.
No external back up I'm afraid, just a RAID10 config of the RN3138.
- StephenBJan 29, 2024Guru - Experienced User
You are confusing the space in the root (OS partition) and the data volume. The root is only 4 GB (not TB), and holds the linux OS, the ReadyNAS application software, and the NAS configuration files.
It would be prudent to make a back up right away.
- jonbloke3276Jan 29, 2024Aspirant
Sorry for being new at this. How do I access the root folder in order to check this? Do i need to enable SSH access?
Download the log zip file from the logs page, and open volume.log. Scroll down to the === df -h === section. /dev/md0 is the root.
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1014M 2.8G 27% / tmpfs 1.9G 0 1.9G 0% /dev/shmOn this NAS you can see it is 27% full. This is fairly typical.
