Jaap74
Jan 13, 2012Aspirant
Songs not playing in correct order on Twonky
Hi, Just installed Twonky on the ReadyNAS Duo with some help from this kind board however the songs in albums don't play in the correct order. I had the same issue when I had Twonky on my PC so I d...
Jaap74
Actually it was simpler than I thought, I found the XML files and have replaced them :-)
