dk0r's avatar
dk0r
Guide
Aug 19, 2011
Subsonic 4.5.03 --Crashing
@Super-Poussin,
The issue in the following post from this thread seems to be reoccurring throughout all versions of both subsonic (including 4.5.03) and radiator (including 4.2.19).
dhl wrote:
@Super-Poussin,
"...I'm noticing a couple issues with version 4.5.02. I'm running it on a Pioneer Pro at 4.2.17.
1) the green on-status indicator turns off after refreshing the browser window (even though the server is running).
2) the subsonic server eventually stops running (crashes?) and needs to be restarted manually.
I've seen other threads about a crash problem with an older version of the add-on. Was wondering if you had any advice about these problems in the current version..."
  • This plugin continues to crash daily.
    @Super-poussin, is there any chance of a fix?
ProSupport for Business
