cvernon1
Nov 05, 2012Aspirant
Subsonic no Video Streaming
Hi, I just installed subsonic 4.7.beta3 (build 3060) – August 2, 2012 on my readynas ultra. music streaming working perfectly, video won't stream in any format, error message is: "video not fo...
pkas
Nov 21, 2012Tutor
I had the same problem, but here's how I fixed it:
1) Go the Settings tab of your Subsonic server
2) Click the Transcoding link
3) For the video setting, carefully change "ffmpeg" to "/usr/local/bin/ffmpeg" (leave the rest of the command the same).
I think there are two ffmpegs installed, and it turns out that the one in /usr/local/bin supports the -preset option; the other one does not.
Good luck!
pkas
Good luck!
pkas
