ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
pkas
Oct 07, 2012Tutor
Ok. well one thing that is wrong is that you have two instances running.
Via ssh, kill BOTH instances:
Then, copy and paste the following as a shell command (it is a SINGLE command)
Do NOT use the launcher for now. Do NOT try to start or restart subsonic via FrontView. Just use the above command.
After executing the above command and before doing anything else, check to see if subsonic WORKS. Do NOT worry about FrontView. Instead, what you want to do is to use the ip address of your ReadyNAS and port 4040 as a URL. For example, if your ReadyNAS has an ip address of 192.168.1.101, then you would open a web browser and use the foilowing URL: 192.168.1.101:4040
So, go to that URL and let me know what you see.
Phil
kill -9 24270
kill -9 24408
/c/webroot/subsonic/jre1.6.0_20/bin/java -Xmx700m -Dsubsonic.home=/c/webroot/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/c/media/music -Dsubsonic.defaultPodcastFolder=/c/media/Podcast -Dsubsonic.defaultPlaylistFolder=/c/media/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
Phil
