ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
pkas
Oct 09, 2012Tutor
Oops, sorry.
Before trying to execute the long command, you have to do the following:
cd /c/webroot/subsonic
Once you are in the correct directory, you'll be able to execute the long java command.
Phil
Phil
