ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
xsspeed03
Nov 21, 2012Aspirant
OK, I tried it. We shall see if it works. I'm sure it will if it worked for you. If I don't post back, that means it worked. Thanks in advance for the tip.
