ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
dsm1212
Nov 21, 2012Apprentice
I posted a tiny cron job script I use to keep subsonic running a while back. This isn't a new problem.
Anyhow I wanted to say the reason that the checkbox doesn't stick on frontview for subsonic running is that the addon failed to add the line SUBSONIC=0 to /etc/default/services. The line for SUBSONIC_SUPPORT=1 was added but not the line that stores the current state. If you add a line SUBSONIC=1 when you have subsonic on then it will persist when you turn it on and off. Now this line was there before so the addon update must have actually removed it.
