ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
pkas
Nov 21, 2012Tutor
Thanks dsm1212. In my case, there already IS a line: SUBSONIC=1 in the /etc/default/services file, but the indicator does not remain on. (That is, I did not just add the line -- it has been there.)
I'd like to see your cron script -- I'd like to see how you launch subsonic if it is not running. I didn't know how to find the parameters to pass unless I examined the output of 'ps aux' just before the command that causes subsonic to die. I'm curious how to do this the "right" way.
Thanks,
pkas
Thanks,
pkas
