ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
dsm1212
Nov 22, 2012Apprentice
Weird that you already had the line and still have the problem. The one should change to a zero when you turn the service off and back when you turn it on. Maybe its the last line in the file and needs a newline?
The script is in this thread: viewtopic.php?f=22&t=50677&start=15.
It actually will only restart once because then it was started by cron and not apache so it doesn't die every day. I had it running every 15 minutes but you could probably just run it after the daily job that on my system runs at 6:25. Now here's the thing I just realized, I had gone through some upgrade downgrades and I no longer had the cron job set up, but my subsonic has not been crashing. I'm thinking a subsonic update must have started handling the signal correctly. I've got subsonic 4.7 final installed now. What version are you seeing this on?
Steve
Steve
