ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
pkas
Nov 25, 2012Tutor
Ah, ok. Do I need to (or should I) uninstall the version I currently have installed before installing the new vesrion? I wasn't sure if performing an update cleaned up old stuff before installing new stuff.
Thanks!
Thanks!
