ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
dsm1212
Nov 25, 2012Apprentice
I wouldn't uninstall unless the addon is wedged and you're trying to fix that by starting from scratch. Running the addon install from the install window or doing an update from the addon list is really equivalent.
steve
steve
