ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
gibxxi
Nov 26, 2012Guide
If you want to start from fresh you can uninstall and select "no" to let it remove the existing configuration data when asked. If you believe the app is malfunctioning, but can't pin it down to installation files, or config - this would be the route to take. But you will have to set it up again from scratch.
Otherwise, just install over the top of the existing one.
