nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
super_poussin
Sep 02, 2009Virtuoso
apr is compiled and isntalled but
r2-d2:/Develop/svn-src/subversion-1.6.5# ./configure --build=sparc-linux --with-apr /usr/local/apr/lib
configure: WARNING: you should use --build, --host, --target
configure: WARNING: invalid host type: /usr/local/apr/lib
configure: Configuring Subversion 1.6.5
configure: creating config.nice
checking for /usr/local/apr/lib-gcc... no
checking for gcc... gcc
configure: WARNING: using cross tools not prefixed with host triplet
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... yes
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for /usr/local/apr/lib-g++... no
checking for /usr/local/apr/lib-c++... no
checking for /usr/local/apr/lib-gpp... no
checking for /usr/local/apr/lib-aCC... no
checking for /usr/local/apr/lib-CC... no
checking for /usr/local/apr/lib-cxx... no
checking for /usr/local/apr/lib-cc++... no
checking for /usr/local/apr/lib-cl.exe... no
checking for /usr/local/apr/lib-FCC... no
checking for /usr/local/apr/lib-KCC... no
checking for /usr/local/apr/lib-RCC... no
checking for /usr/local/apr/lib-xlC_r... no
checking for /usr/local/apr/lib-xlC... no
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking build system type... sparc-unknown-linux-gnu
checking host system type... /usr/local/apr/lib
configure: error: invalid value of canonical host
