nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
super_poussin
Sep 02, 2009Virtuoso
that's better but :
checking for Apache module support via DSO through APXS... no
WARNING: skipping the build of mod_dav_svn
try using --with-apxs
configure: checking sqlite library
amalgamation not found at /Develop/svn-src/subversion-1.6.5/sqlite-amalgamation/sqlite3.c
checking sqlite3.h usability... no
checking sqlite3.h presence... no
checking for sqlite3.h... no
checking sqlite library version (via pkg-config)... no
An appropriate version of sqlite could not be found. We recommmend
3.6.13, but require at least 3.4.0.
Please either install a newer sqlite on this system
or
get the sqlite 3.6.13 amalgamation from:
http://www.sqlite.org/sqlite-amalgamation-3.6.13.tar.gz
unpack the archive using tar/gunzip and copy sqlite3.c from the
resulting directory to:
This file also ships as part of the subversion-deps distribution.
configure: error: Subversion requires SQLite
