nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
WhoCares_
Sep 11, 2009Mentor
The version I linked to above is for the Duo, NV, NV+, 1100 (and X6?).
Actually I just found a small bug, so there's a new version 1.0.5 coming up that installs cleanly and which also should uninstall without problems.Currently, it is working flawlessly on my NV+ and my DUO.
May I ask what you'd be using it for? Depending on your needs I possibly need to change a couple of things before it's really useful to you. Right now it's mostly tailored to being used as the root user on the command line.
-Stefan
-Stefan
