nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
WhoCares_
Sep 13, 2009Mentor
super-poussin wrote: links sounds broken ...
Argh. I again copied from the wrong browser window (now finally closed ...). Thanks for the heads up, I fixed the links in the original post.
Btw: Would you mind updating PHP_1.1.bin so that it requests a reboot from the user? All that's needed to do that is copying the build_addon script to build_boot_addon. In the new build_boot_addon just remove the "skipreboot=1," from the line reading
echo "addon::name=${FRIENDLY_NAME},version=${VERS},time=${TIME},size=${SIZE},md5sum=${MD5},unencrypted=1,skipreboot=1,api=1,arch=$arch" | dd conv=sync bs=$bs >index 2>/dev/null || error(line 4 from the bottom of the script on my system)
Stefan
