nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
EOne
Sep 16, 2009Aspirant
Doh...I downloaded it again and saw I already downloaded also the PRO version. Accidentally installed that one.
Now installed to one for my ReadyNAS DUO.
I have now the following error when going to https://mynas/websvn
Unable to find 'svn' tool at location '/opt/rfw/bin/svn'
Do I need to change an option or something?
edit: btw, I have SVN 1.6.0 installed. Dont know yet how to upgrade to 1.6.5 if needed.
edit2: it seems that I have it at /usr/local/bin/svn (tried command whereis svn, that gave me that answer). Still relearning linux commands :)
edit3: Change the line according to that svn location in the config.php to my path. Now the web page is showing but no repositories (yet). I suppose somewhere in the config.php I need to set my path to the root dir of my repositories (/d/data/Servers/Subversion/Repositories)?
Edit4: After reading the config.php a bit I found that one too :) Now I see my rerositories.
I have a question for Super-Poussin. I now use a 'batch' that creates my repository and does some other things for user rights and makes some ln's in the created repository. Is it possibile that I set it the interface to use that file to also run?
Just a thought.
Just a thought.
