nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
WhoCares_
Sep 16, 2009Mentor
EOne wrote: edit: btw, I have SVN 1.6.0 installed. Dont know yet how to upgrade to 1.6.5 if needed.
Actually, the easiest way for you would have been to install the subversion addon first, then WebSVN and afterwards either move or symlink your repos to /opt/subversion. Or maybe to even install WebSVN manually like you did with Subversion 1.6.0. Either way would have saved you a lot of troubles I guess.
EOne wrote: I now use a 'batch' that creates my repository and does some other things for user rights and makes some ln's in the created repository. Is it possibile that I set it the interface to use that file to also run?
Of course. Since you already quite ripped apart everything else, I'm quite confident you'll find where to patch that in, too ;)
Stefan
