nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
WhoCares_
Sep 17, 2009Mentor
Pettax wrote: When accessing the repository over https it seems like I only need to enter my credentials when I am writing to the repository, i.e. reading from it does not require credentials. Is this a setting somewhere?
If I'd be Microsoft, I'd say "works as designed" ;)
Actually, you can change that behavior, but you have to make these changes manually.
SSH to your ReadyNAS, there change to the directory /etc/frontview/apache/addons/. There you'll find the file SUBVERSION.conf. Within this file, just comment the <LimitExcept ...> and the </LimitExcept> lines by putting a # in front of them. Save and check the new config using "apache2 -t -f /etc/frontview/apache/httpd.conf". If this results in a "Syntax OK" message, restart the web server of your ReadyNAS using "killall -USR1 apache-ssl". Wait for about 60 seconds while Apache reloads its config. Now you should be asked for your credentials even when only displaying or checking out the repositories.
-Stefan
