nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
WhoCares_
Sep 18, 2009Mentor
Warren,
Basically, all you need to do is install the Subversion and the WebSVN .bin files through the Update function of Frontview. The SSH things are just neccessary if you want to change some of the underlying settings (e.g. if you don't like the defaults I provided with the Addons).
Would this and that be good enough as additional info for the moment, or do you need some more details? If so, just go ahead and ask what you want to know.
Stefan
Stefan
