nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
Pettax
Sep 18, 2009Aspirant
WhoCares? wrote: SSH to your ReadyNAS, there change to the directory /etc/frontview/apache/addons/. There you'll find the file SUBVERSION.conf. Within this file, just comment the <LimitExcept ...> and the </LimitExcept> lines by putting a # in front of them. Save and check the new config using "apache2 -t -f /etc/frontview/apache/httpd.conf". If this results in a "Syntax OK" message, restart the web server of your ReadyNAS using "killall -USR1 apache-ssl". Wait for about 60 seconds while Apache reloads its config. Now you should be asked for your credentials even when only displaying or checking out the repositories.
Thanks again! Works as expected (on my ReadyNAS Duo for the record).
/Pettax
