nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
jcouvret
Oct 15, 2009Aspirant
I didn't see anyone else discussing this issue - if you use the ReadyNAS device as a subversion server, how do you backup your repositories? I currently use two external hard drives, rotated weekly, as offsite backup of critical data on the ReadyNAS device. I use the backup settings on the FrontView to set up those backups. I don't see any way to access the /opt/subversion path using the FrontView backup settings. Is anyone else backing up their subversion repositories? My best guess is that I will have to use a rsync cron task, but I wanted to know if anyone else has tackled this yet? If not, I could also use help scripting the rsync to an external hard drive attached to the front backup port of the ReadyNAS Pro. Thanks!
