nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
Playjoy
Dec 13, 2009Aspirant
stevepiercy wrote:
Playjoy wrote: When I commit, I need to enter my admin credentials instead of my regular user credentials.
Any Idea how to change that?
Sounds like you installed only the SVN plugin, and not those that allow you to use an arbitrary user.
See the last bullet point under Details in this thread.
http://www.readynas.com/forum/viewtopic.php?f=47&t=33337
Thanks for your answer.
I only try to access the repository via http/https. Or I assume I try that.
I use https://serveraddres/svn/repo to connect with tortoisesvn, is my assumption incorrect? Is it svn+ssh: because I use a svnclient?
