nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
efalsken
Apr 30, 2010Aspirant
You do that on your client machine that you check in from. And the location depends on which svn client you're using. (TortoiseSVN stores its config in %USERPROFILE%\AppData\Roaming\Subversion)
