nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
cdubea
Apr 30, 2010Aspirant
efalsken wrote: You do that on your client machine that you check in from. And the location depends on which svn client you're using. (TortoiseSVN stores its config in %USERPROFILE%\AppData\Roaming\Subversion)
Awesome. Thanks!
chris
