nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
buttertoad
Mar 05, 2012Aspirant
Well, I do still have the issue it seems. I had done a factory reset and then I installed the addons and it worked. I had WebSVN working as well, but then all of a sudden it started doing the same thing. Anytime I try to create a repo I get the I/O error whether it's with the CLI or through the WebSVN interface.
At first I thought it might have something to do with NFS but disabling NFS doesn't seem to make a difference and my repos aren't on the NFS share anyway.
I have to admit this has me stymied, I've gone though ReadyNAS and Subversion forums and I can't seem to find anyone with a similar problem. I'm probably doing something stupid but if you could point out what it is I would appreciate it. :)
